E40D trans swap
Old Oct 28, 2006 | 07:21 PM
jimbucajoe's Avatar
jimbucajoe
E40D trans swap
I am inerested in any advice in swaping this trans to replace my NV4500 trans. Its going in a 1968 F-250 w/ 460. will I need to make any electrical system changes? Any help will be greatly appreciated. Joe
Old Oct 28, 2006 | 10:31 PM
Josh88Ford's Avatar
Josh88Ford
should go with a c6 instead of a e40d
Old Oct 28, 2006 | 11:29 PM
donnor's Avatar
donnor
E4OD in 68 F250: anachronistic twists
Wow. This could be quite an undertaking. Not impossible, but a good challenge. Since the E4OD is electronically controlled you will need to incorporate an electronic fuel injection for your 460. I would suggest that you find a good donor truck (if you haven't already done so) from the early to mid 1990s to give you the computer and wiring loom with the sensors that send the signals needed by this tranny to operate. Shift linkage will also be a sub-project. Some malign the E4OD, but properly built it is a great unit. My 95 has 340,000 miles on it with nary a problem.
A search of this site's technical articles will also be helpful. But even more, you will want a wiring diagram to help put it all together.
Swaps that take newer technology and put it to work in classic vintage vehicles I find particularly interesting. I wish you well in this endeavor & look forward to hearing of your progress! Could you also post pictures at various steps with relevant descriptions? This encourages others in such projects.
dn.
Old Oct 29, 2006 | 09:16 AM
lostin90s's Avatar
lostin90s
They make a stand alone controller for the E4od. Was descussed in post not long ago . Wish I would Have Paid attention to it now. Good luck
__________________________________
94 F150 XLT 4x4 SC LB Maf 302 E4od
Old Oct 29, 2006 | 09:50 PM
brett15's Avatar
brett15
I think the company that makes the stand alone control is called "baumann electronic controls"
Old Oct 30, 2006 | 12:39 AM
BigBully's Avatar
BigBully
There are a few companys that make transmission controllers, http://www.compushift.com/compushift.htm
http://www.becontrols.com/products/electronicscat.htm
http://www.powertraincontrolsolution...content-4.html
here Are the ones I know of.
I am in the proccess of installing an E4OD in my 79 right now, so far its been pretty easy to make the harness. You dont need any kind of Fuel injection, you can just adapt a TPS onto your carb. easy to do.
The other Joe
WTB - Parts & other
May 23, 2014 04:42 PM
joe blow
Oct 26, 2011 06:13 PM
DR JOE
Oct 28, 2006 12:52 PM
joe53051
Dec 2, 2002 04:27 AM
