IAC valve?
Old Oct 28, 2006 | 04:46 PM
Wthomaslee's Avatar
Wthomaslee
IAC valve?
I changed the IAC valve today because of hard starts. Before, it would start and die start and die. I could give it a little gas and it would run to get going, or peck a little on the IAC valve to temporarily fix it. No codes would come up. Now after I changed the IAC it runs High and low and comes up with a P1506 code. Un known powertrain DTC (manufacturer controlled: vehicle speed... The rest of the details are cut off of my scanner tool. Any ideas?
Old Oct 28, 2006 | 09:50 PM
orleec's Avatar
orleec
Per my book for Ford Specific code:
P1506 - IAC Overspeed Error (nothing follows)
I don't know exactly what this means, but I hope this would somehow help.
Old Oct 29, 2006 | 07:17 AM
vze2sgxa's Avatar
vze2sgxa
Did you reset the computer by disconnecting the battery cable?
Old Oct 29, 2006 | 02:17 PM
Wthomaslee's Avatar
Wthomaslee
Yes, after I did this it codes P0171 and P0174. System too lean on bank 1 and 2. Now I am really lost. It still idles high and low from 400 to 1500 rpms in park and dies to trying to runaway in drive. any help?
Old Oct 30, 2006 | 06:22 AM
orleec's Avatar
orleec
P0171 and P0174 have been posted here as a common problem about PCV elbow that leaks. The said elbow is about the same area where the IAC valve is, so it's possible you have a rotting elbow and you somehow 'touched' it while working on IAC valve and made any impending leak/hole worse.
Search the board for PCV elbow or P0171 and P0174, there should be a lot of information you can use.
Personally never had this problem, and in fact, tried hard to find this elbow and couldn't find it, mine seems to have a straight reducing rubber connector and not an elbow in the general area described above.
Good luck.
Old Oct 31, 2006 | 07:07 PM
Gevans17's Avatar
Gevans17
Clean your mass air flow sensor
