BIG Difference?
Old Oct 28, 2006 | 03:03 PM
315X75r16ExpyEB's Avatar
315X75r16ExpyEB
BIG Difference?
as of right now i have a powerdyne supercharger, shorty headers, transgo shift kit, flowmaster 40 series muffler, lift with 315 75r16 tires my gear ratio is stock 3.73 and was thinking about gearing to 4.10 would this make a big difference, would i be able to get a little chirp out of the tires or even get a better jump when i put my foot down. im sure it would just wanted to know if its worth the $500 for both front and rear plus cost of special tools
Old Oct 29, 2006 | 05:03 PM
85e150's Avatar
85e150
Chirp the tires? Sure, just run it up to 4000 rpm in neutral and pull it down into drive. Chirp city.
Go here and plug in your numbers to determine rpm change with new gears.
$500 for gears and labor? Very low.
http://www.novak-adapt.com/knowledge/gearing.htm
Old Oct 29, 2006 | 05:34 PM
captchas's Avatar
captchas
Guest
with those big tire i would think more in line of 4;30's or 56's with going up 1 step to 10's you will feel you cheated your self. use the other mans link and go up 1 step past in case you want a even bigger tire next trip to reshoe.
my 05 had 10's i now have 56's and am darn happy with my all around performance gain useing the stock sized and costly 17 inch tires .
Old Oct 29, 2006 | 06:05 PM
315X75r16ExpyEB
im just paying for the gears and install kits i have a buddy that owes me about 600 worth of labor and he installs ring and pinions. thanks for the advice and the link i am going to go with the 4.56 ratio i think that should to the trick
