rough idle problem
Old Oct 27, 2006 | 07:35 PM
the kid's Avatar
the kid
rough idle problem
hi i just got an 84 f150 with a v6. im having prolems with the idle it want to miss and stall. i put in new plugs cap and rotor and plug wires it still dose it. i tryed to tune the carb but still happens what should i try next
thanks
Old Oct 27, 2006 | 08:59 PM
locknkey's Avatar
locknkey
Have you checked to see if its partly flooding out? Too much choke will make it run like that also....Lean an rich mixture screws could also make a lean condition. Also a vaccum line could be sucking air and causeing rough idle, or loose carb bolts around carb. intake.
Old Oct 27, 2006 | 10:10 PM
the kid's Avatar
the kid
well i was looking at it to and it looks loke the egr was un hooked how can i trace down the vac lines for that
Old Oct 27, 2006 | 10:23 PM
the kid's Avatar
the kid
were can i get a vac line schematic
Old Oct 27, 2006 | 10:33 PM
the kid's Avatar
the kid
i was told by a moron that sometimes old trucks run better with the egr un hooked like mine is. is there a way to test it to see. i dont even know where to start looking for the vac line that hooks to it. thanks and sorry for all the stupid questions
Old Oct 27, 2006 | 10:52 PM
williamm21's Avatar
williamm21
I believe thaty the egr should be connected if it is there, I say this because in one position it would cause a vacum leak. That would be bad oh....I belive a diagram would be on the underside of the hood...called an emmission control label. I am a new user like you but most users here comment to get a plate and seal it to take care of the vacum leak...of course this would be relative to the state you live in cause of the emmission laws in some union states.....to where that thing hooks....my guess would be the place that is unhooked and on the low pressure side....
Old Oct 28, 2006 | 08:27 AM
victorcharlie's Avatar
victorcharlie
Buy a vacuum guage......20 to 21 is normal.....
