High Idle
Old Oct 27, 2006 | 05:56 PM
dracip's Avatar
dracip
Question High Idle
1992 F-150 4.9 5spd runs great but has developed a high idle. so far I have cleaned the Idle control valve with carb cleaner. No Change. A repair manual I have said that with the key on, engine not running I should get 10.5 volts at connector from the PCM (Computer) - I got full battery voltage 12volts +. I also Ohmed the actuator and got correct reading any recommendations. Thanks Tom
Old Oct 27, 2006 | 07:33 PM
andym's Avatar
andym
A high idle is more often caused by a vacuum than anything else.
Old Oct 28, 2006 | 05:36 PM
dracip's Avatar
dracip
found problem - it was loose egr valve bolts - once tightened truck running perfectly - I had previously changed out the egr valve. Problems usually start where you do something on the truck. This was my fault for not tightening the bolts properly. Always check your own work before suspecting every other factory vacuum connection.
