Changing frames ?
Old Oct 26, 2006 | 09:52 PM
hot428ford's Avatar
hot428ford
Changing frames ?
Wanting to find out if the 67 to 73 body will bolt on a trk from 73 to 79 ??? Thanks ....YES ITS A FORD.
Old Oct 27, 2006 | 06:25 AM
jowilker's Avatar
jowilker
Yes it will.
John
Old Oct 27, 2006 | 07:12 AM
FordBoypete's Avatar
FordBoypete
Thumbs up
The BODY GROUPS in FoMoCo F Series, by year, run 65 & 66 , 67-72, And 73-79. As usual John is spot on with his answer, the 67-72s fit in a virtually bolt up manner with a little adaptation.
The WB is slightly longer on 73-79s & Rear frame width in C/A or Cab to Axle area is a little wider.
Never the less my 66 F-100 Styleside, CC, SWB sits on a 79 F-150 Trailer Special SWB chassis and all it took was fudging the bed a tad and fabricating new mount holes to fit the 3" wider C/A. . . .
If you run into problems ask, we'll be here to help ya.
FBp
