ball joints
Old Oct 26, 2006 | 09:06 PM
luke245's Avatar
luke245
ball joints
I'm replacing my ball joints, but the cottier pin and bolt are rusted together. Does anyone know of any kind of impact wrench or tool I could use to loosen the bolt?
Old Oct 26, 2006 | 09:12 PM
G-Dog's Avatar
G-Dog
just cut the cottier pin on both sides and use a inpact gun on it what kind of truck is it
Old Oct 26, 2006 | 09:39 PM
luke245's Avatar
luke245
yeah i just cut the cottier pin off but the bolt wouldn't budge. it's a 92 f150
Old Oct 27, 2006 | 04:44 AM
Chumbucket's Avatar
Chumbucket
Bolt
Hey, Luke i just did 92 150 2 wheel what bolt ??
Old Oct 29, 2006 | 11:34 PM
luke245's Avatar
luke245
it's on the upper front ball joints on both sides. it is all rusted together.
Old Oct 30, 2006 | 04:54 AM
mississauga's Avatar
mississauga
Try and find the hole where the cotter pin went thru and drill it out. Applying some heat to the nut and remove the nut with an impact wrench should do the trick.
Old Oct 30, 2006 | 04:08 PM
G-Dog's Avatar
G-Dog
heat it good and an impact gun should get it off
Old Oct 30, 2006 | 09:40 PM
NeoCowboy's Avatar
NeoCowboy
Get it hot, red hot isn't going to hurt anything, your replacing the joint and nut anyway. I have found that a lot of times an impact gun isn't as good as just a good 3/4" drive braker bar and socket. If you get it hot and still can't move it, heat it again and jam an old candle on the threads as close as you can get to the nut. It was a trick that I read on here for getting the nut off the radius arm but it works on pretty much anything you can heat the nut up on. Capilary action will suck the wax into the treads and make it a lot easier to break free.
Old Oct 30, 2006 | 09:42 PM
Josh88Ford's Avatar
Josh88Ford
Sometimes impact won't work if its really rusted, especailly with a cheapo impact. Have to break the nut loose before impact.
Yeah, either drill or hit a nail through the cotter pin hole to get that out. breaker bar with a 4 foot pole should do it. Otherwise you'll have to try some other things
Heat the nut up, then try. Heat the nut up and melt some wax onto it. If the wax can penetrate, it will dry and expand...you know how wax is.
If all else fails, Sawzall does wonders
