51 master cylinder
Old Nov 7, 2002 | 10:05 AM
maxwellthefatcat's Avatar
maxwellthefatcat
51 master cylinder
Old Nov 8, 2002 | 04:26 PM
51truck's Avatar
51truck
51 master cylinder
Does anybody know of a dual reasavor master cylinder that will fit in the stock locaton, that will bolt in with out any mods. Thanks
Old Nov 8, 2002 | 10:39 PM
jeffh's Avatar
jeffh
51 master cylinder
I'm thinking about this myself. :-) I know Master Power Brakes sells dual cylinder and power booster, and also disk brake kits. http://www.mpbrakes.com/
Old Nov 8, 2002 | 11:07 PM
BlueOvalRage's Avatar
BlueOvalRage
51 master cylinder
There is no direct replacement for the stock master cylinder that I am aware of, but there are several bolt-on adapters available that are relatively inexpensive compared to the huge gains in safety and master cylinder availability. Check with Sacramento Vintage Ford.
Old Nov 10, 2002 | 06:59 PM
51frrdtrk's Avatar
51frrdtrk
51 master cylinder
I bought a duel master cylinder (mustang)along with the mounting adapter and a couple of reducer fittings for the lines. I had the unit installed in a couple of hours.
I would suggest changing the brake lines and hoses first. Your more likely to have one of these fail.
