installing cat back?
Old Oct 26, 2006 | 04:54 PM
clings89's Avatar
clings89
i just ordered a dual force flowmaster, cant wait till it comes in but any how is there any tips or tricks i should know about before installing it? thanks alot jim
Old Oct 26, 2006 | 08:03 PM
Bob Jusnes's Avatar
Bob Jusnes
If you dont have a lift, you may need to cut the rear pipe to get it out of the truck. I cut mine right above the axle. Also, if you are 05 up, your front pipe will take a 1/4 twist to unlock it from the Y pipe, after you take the clamp off. some late 04s may be like this too, the easiest way to tell is to look for a "pinch" in the midpipe.
Old Oct 26, 2006 | 08:14 PM
Brian429's Avatar
Brian429
Well getting your old system off is definately the hardest part of the project. The stock muffler weighs as much as a VW bug, I found this out the hard way as I dropped in on my thumb. (not smart) Having a extra set of hands will help out too, so if a buddy owes you one, call him up!
Old Oct 26, 2006 | 08:51 PM
The Oldtimer's Avatar
The Oldtimer
I installed my cat back FlowMaster myself without a lift. Bob is right...cut the tailpipe off behind the muffler. It will come out real easy. Prop up the stock muffler with something...a jack stand works best. That sucker is heavy!!
The tailpipe install can be a pain, because it is hard to install both of the rubber hangers onto the frame mounted round stock steel thingies at the same time. I ended up cutting a piece off off one to make it easier to slide the rubber hanger on. Put some liquid soap on the brackets and the rubber hangers to make them slide together easier.
It took me about two hours, 4 beers, one pit stop...and I'm 65!!
Old Oct 26, 2006 | 08:55 PM
Bob Jusnes's Avatar
Bob Jusnes
Hey, thats not a bad time, even if you were 25!
Old Oct 27, 2006 | 02:33 PM
MIKESANDS's Avatar
MIKESANDS
SHOWOFF!
Old Oct 30, 2006 | 09:55 PM
clings89's Avatar
clings89
thanks alot guys, i just got it in the mail today. cant wait to put on. i shere all these tips will be helpful
jim
