Sponsored by: Auxito
2002 f150 fx4
Old Oct 25, 2006 | 06:39 PM
crayznsain's Avatar
crayznsain
Angry 2002 f150 fx4
I started having a "tinking" noise somewhere near the driveshaft recently. It only happens when coasting and almost sounds like i'm dragging a piece of metal on the ground and its bouncing off the pavement going, "tink, tink, tink". not only is this very annoying but it is embarrassing that my Ford sounds this way. its not something hitting the drive shaft, i know that much. Any ideas would be greatly appreciated.
Old Oct 26, 2006 | 11:49 AM
LxMan1's Avatar
LxMan1
Check the u-joints, possibly one is a bit loose.
Old Oct 27, 2006 | 08:58 AM
crayznsain's Avatar
crayznsain
u-joints seem to be ok. all exhaust hangers are tight. i'm at a loss here.
Old Oct 27, 2006 | 09:50 AM
Racerguy's Avatar
Racerguy
Welcome to the forum crazynsain
Quite often you won't find a bad U-joint without actually removing the driveshaft to check them. If you have one that's seized it will feel ok but when you remove the shaft you'll find that it doesn't move freely.
Old Oct 27, 2006 | 10:13 AM
crayznsain's Avatar
crayznsain
and the u-joints could be making that tinking type of noise? if so, i can pull the drive shaft to check that, correct?
Old Oct 27, 2006 | 10:19 AM
Racerguy's Avatar
Racerguy
correct
With the shaft removed both U-joints should move freely and smoothly with no binding or roughness.
Old Oct 27, 2006 | 10:21 AM
crayznsain's Avatar
crayznsain
is there a torque on u-joints.
Old Oct 27, 2006 | 05:12 PM
crayznsain's Avatar
crayznsain
tore it apart and it was the rear u-joint. a 100 bucks later its fixed. thanks for the advice.
Old Oct 27, 2006 | 07:11 PM
Racerguy's Avatar
Racerguy
Good to hear
