Door Removal
Old Oct 25, 2006 | 12:15 PM
mackedisto's Avatar
mackedisto
Door Removal
I have a 1991 Explorer with a damaged drivers door. I plan to swap out the door with a 94' that I canablize. My question is pretty simple. When removing the door where is the electrical i.e. the p/w, p/dl, speaker wires disconected? Is it at the switches, at the door jamb or inside the kick panel? My owner repair manual tells me how to remove it at the hinges but says nothing about the electrical wiring. Thank You
Old Oct 27, 2006 | 06:24 PM
vicv's Avatar
vicv
I've not removed the entire door but have removed the door panel on my 97. I can disconnect at the switches and speaker.
Old Oct 28, 2006 | 02:31 AM
shiloh66's Avatar
shiloh66
Unplug all the wires at their connections, take a screwdriver and work the grommet out of the door frame , then pull the wires and grommet out the door.
