clunking noise in front end
I have a 2000 superduty 5.4 4x4 i have been to a ford dealer and frontend shop they both have ruled out ball joints and said they were tight as can be. They replaced tie rod end at pitman arm and it helped a little bit but still did not fix clunking, it is almost like metal hitting the frame right under my feet while driving. please help its driving me nuts!!!
Check your front sway bar link bushings. My 2000 did the same thing and the sway bar bushings came up through research. Sound went away for good after replacing them. I recall the bushings are not sold separately, which requires you to replace the link on each side as an integrated piece.
I had the same problem. The bigger issue is that the parts places do not carry the links. I calle dthe dealer and they wanted almost 80 bucks FOR ONE!.
Go to fordpartsonline.com. I found them for 41 and change each. OEM parts. I should have them by Monday and wil put them on that night.
Good luck
Good luck
another thing to do while replacing the links is to replace the sway bar bushings on the axle, then drill a hole through the metal clamp that hold them on and through the bushing, add a grease zerk fitting into the clamp. Now you have something else you can grease and make it last alittle longer
Isolate the noise by having someone bounce on the truck while you are under it. Hold your hand on the link and you will feel it shift or thud if it is bad. That's how I found mine.
Look back to my message where I found the parts online. Otherwise, you will have to go to the dealer and pay almost twice the cost.
