General Automotive Discussion
95 jeep starting problem
Old Oct 25, 2006 | 12:49 AM
omni's Avatar
omni
I know theres some pretty smart guys on this site so I thought I would ask this here. I bought a 95 yj 2.5L to haul the dog around. the problem I'm having is it starts like the timing is way off(you know how it drags for a few seconds then wirls over) seems to be getting worse. I understand you can't adjust the timing on these motors, it preset from the factory. I did get a code-54(no cam sync signal at PCM) is there a sensor that would effect the timing some how at start up? the cables look new and so does the battery
Old Oct 26, 2006 | 11:42 PM
ChaoticBaz's Avatar
ChaoticBaz
Try checking the Crankshaft positioning sensor.Usual jeep issue
Old Oct 27, 2006 | 06:13 AM
06supercrew's Avatar
06supercrew
You might try checking the starter also.
