1978 - 1996 Big Bronco
Heater Core
Old Oct 24, 2006 | 11:02 PM
GIXXED's Avatar
GIXXED
Heater Core
Anybody have problems with thier heater cores leaking. I replaced mine about 3-4 years ago I replaced it with a new one. Now it is leaking again. WTF
Just wondering if this is an issue or if this is an issue happening from something else that may be happening.
1990 Bronco 302 (5.0) AOD tranny about 70k on the engine and about 200k on the Tranny. Need anything else?
Thanks again
Old Oct 24, 2006 | 11:31 PM
Bimmerboy1989's Avatar
Bimmerboy1989
just be glad you don't own a 96 or later mustang. You have ot take the whole dash out to get to the heater core. Heater cores seem to have a problem with failing. What kind of coolant are you running? if it's straight water then thats your problem. Coolant carries rust inhibitors, and if coolant isn't used in a twenty percent or greater(usually 50/50 is most common) concentration then rust will form in the cooling system causing the premature failure of cooling system parts. Also change the coolant once a year to maintain the qualities of the coolant.
Old Oct 25, 2006 | 09:36 AM
GIXXED's Avatar
GIXXED
Yes it is a 50/50 mix it gets flushed every year. That is the one thing I am happy about is at least it is an eay replacement job for me
Old Oct 25, 2006 | 11:00 AM
Bimmerboy1989
What kind of heater core did you get? aluminum or copper? Try switching to a different style of core. if using aluminum try copper or vice versa.
Old Oct 25, 2006 | 08:17 PM
kameronth's Avatar
kameronth
I used to have bad luck with the heater core on my F-100. Even after I flushed it all the time. I have only had to replace the one in my Bronco once. I have had the best luck with the 50/50 as well.
Old Oct 25, 2006 | 10:24 PM
dwoodler's Avatar
dwoodler
Make sure the rubber/foam is still on the mating surface of your heater core box as well as in the fire wall - vibration can kill almost anything over time.
Can you see what the fault is in the heater core? Cracking, core failure, or anything visible?
Old Oct 26, 2006 | 10:25 AM
GIXXED's Avatar
GIXXED
Have not pulled it apart yet to see where it is leaking. I only get that kind of time on the weekends. I believe it is just a stock copper core
Old Oct 27, 2006 | 05:49 PM
TBriggs's Avatar
TBriggs
Same thing with a TBird. The whole freaking dash
Old Oct 28, 2006 | 09:58 AM
GIXXED's Avatar
GIXXED
Oh yes I have had to deal with the whole dash pull apart once. Thank goodness the bronco is a 15 - 30 minute job
