..i got the phantoms oil presure and water temp gauges.i got them electric...are they just as good as the liqid ones. i realy didnt like the thought of hot oil and coolent running in plastic lines in the cab
You're good with the electric ones. Just ordered some myself actually. Should be just as accurate, and much easier to hook up. You'd need some isolators if you wanted to run those gauges into the cab, and wanted mechanical gauges.
