Need advise...
Old Oct 24, 2006 | 10:47 AM
Marty86's Avatar
Marty86
Need advise...
Apparently the reason I wasn't drawing fuel from the rear tank, is because the fuel pump in the tank is bad. Lucky for me, the tank is fuel. Can anyone give me some tips on how to drop the tank without spilling it everywhere? Two jacks raising it and lowering it?
Also, where can I buy a proper service manual, like what they use at the dealerships? My Hanyes manual doesn't show things like how to replace the seal on my power steering gearbox....
Old Oct 24, 2006 | 10:50 AM
neevnav's Avatar
neevnav
Yeah it just says go to dealer right? Same problem here...
Old Oct 24, 2006 | 11:29 AM
Marty86's Avatar
Marty86
Exactly. Thats why I posted, to see if someone could help me.
Old Oct 24, 2006 | 01:45 PM
lostin90s's Avatar
lostin90s
I got ford cd manual on ebay I havent got to deep in to it but alot of info. As for the tank problem siphon it out I did one on a 93 and used 1/2 tubing and drained most of it out.(used hand pump) If don't drain use old car rim on top of your floor jack this will spread jacks lift out ot larger area and be more stable. Loosen straps lowwer so get hands in to disconect lines, power, ect. and slowly lower good luck
_______________________________
94 F150 XLT 4x4 SC LB Maf 302 E4od
Old Oct 24, 2006 | 02:29 PM
mikeyswood's Avatar
mikeyswood
The CD on eBay is a great deal. Look for Ford (year) Manual CD and you will find it.
It was me and another guy that dropped my tank when I had to fix a seal. If you are by yourself, clamp the tank to the lift and be careful.
Mike
Old Oct 24, 2006 | 03:39 PM
MustangGT221's Avatar
MustangGT221
I am assuming fuel = full? Your tank is full...?
Siphon the gas out. I used a little $4 siphon and pump kit from walmart because it has a smaller diameter tube than most other kits, and the tubing was cheap so it was kind of stiff. The good tubing you'll normally see is soft and very flexible. The stiffer the tubing the easier it is to get into the tank.
I siphoned the gas out as much as I could before I did my tanks.
Old Oct 24, 2006 | 04:21 PM
quicklook2's Avatar
quicklook2
i have an old external in line pump i use as a siphon.
i have both cd and book manuals from ford and i much prefer the books.
watch for the books to come up on ebay.
more complete and easier to use.
the pump in your tank is the low pressure one, right?
Old Oct 24, 2006 | 11:47 PM
Marty86's Avatar
Marty86
It could be the low pressure one, I'm pretty sure. The high pressure pump is the one on the frame rail.
