Temperature gauge issues
Old Oct 23, 2006 | 09:21 PM
ChurchBuilder's Avatar
ChurchBuilder
I have a 1989 F150 5.8L. The engine light came on and I noticed the temperature gauge was pretty high. Soon it was all the way in the red. No steam or anything, just the gauge pegged. I stopped for a while to cool down and then started home again. As I was driving the gauge went way down to cool for 2 minutes and then back up. By thetimer I got home (2 miles) it was on red again. There is no other sign of overheating.
The top radiator hose was hot and the bottom was not too hot. I checked wires and all look ok. Could this be a bad sensor? Any suggestions?
Old Oct 24, 2006 | 09:43 AM
zoniman1's Avatar
zoniman1
check radiator cap seal, system may not be pressurizing(SP).
Old Oct 24, 2006 | 10:03 AM
Conanski's Avatar
Conanski
Check the fluid level after it cools down. If it's really low you found your overheating problem, but you still have a leak somewhere. If it's not low then you likely have a blown head gasket.
Old Oct 24, 2006 | 11:06 PM
ChurchBuilder
I changed the sensor for the temp gauge tonight. $4.99 at Autozone. That seems to have fixed the problem. If not I'll let you know.
