Aerostar Ford Aerostar
Transmision noise??
Old Oct 23, 2006 | 09:15 PM
9d4's Avatar
9d4
Transmision noise??
I have had a noise in my 94 awd aero That I thought could have been a rod , But upon further review The noise goes away when I put it in park or nuetral. The noise is always present until I do this then there is no noise at all???? Any ideas on what this COULD be.. THANX
Old Oct 24, 2006 | 11:16 AM
yendor's Avatar
yendor
9d4
check flex plate for cracks around the middle or loose bolts in flex plate.Flex plate joins TQ to trannny
Old Oct 24, 2006 | 12:37 PM
Bear River's Avatar
Bear River
Former ******
When was the last time the tranny was serviced? You should probably get the tranny gentle flushed and the filter changed, and look for any abnormal wear inside the transmission.
Old Oct 24, 2006 | 05:35 PM
B-Aerostar's Avatar
B-Aerostar
It might be the transmission valve body pressure spring. I installed a shift kit in my T-Bird and it started buzzing until I put it in gear. But it shifted so much better. The Aerostar did similar when I first changed the shift modulator.
