Dumb radio question
Old Oct 23, 2006 | 12:54 PM
Ed the outdoorman's Avatar
Ed the outdoorman
Dumb radio question
My 98 explorers radio will cut out the left frt speaker when you hit a bump or rail tracks. If you quickly turn up the volume it comes back only to disapear again at the next big bump. I dont belive it's the speaker. I think its in the radio. Anyone else here of this problem in the explorers radios. I think I will be hitting the wreckers to see how much a used one is. The radio is a am/fm cd from factory.
thanks for you thoughts
Ed
Old Oct 23, 2006 | 01:21 PM
marragtop's Avatar
marragtop
Before going to the junk yard, you might want to take a look at crutchfield.com. They have some good stuff, and great installation packages.
Old Oct 23, 2006 | 08:34 PM
denny 280's Avatar
denny 280
I had the same problem in my 04, the speaker was not properly protected at the factory. Ford replaced the left front speaker under warnnty. Yes I saw the old one and the connections were so corroded I am suprised it worked at all. There is a service bulliten out at least on the 04's. I to thought it was the volume control because ti did exactly as you say yours is doing.
