I need some massive help :D
Old Oct 23, 2006 | 11:51 AM
Salem's Avatar
Salem
Ok I bought a 1988 F-250 4x4 with a 351, off a buddy of mine who just needed to get rid of it, picked her up for about 400 bucks. She's got a hole under the driver side of the bench (just needs sheet metal welded in, easy) and some TINY rust by the back wheel wells. I had to replace the steering box which I pulled from a junk Bronco, replaced the brake lines, and I bled the brakes. No air in the lines, plenty of fluid but i still dont have much of a brake pedal. I can deal with that but my main problem is she has trouble starting and under ANY throttle she bogs down and backfires. I know the battery, and altternator are screwed, I'm replacing them soon, but with f-250 diesel jumping it, i have to spray ether in the intake to get her to turn over, and like i said, after she's fired over, if i do anything but even press the throttle, she BOGS down BAD. She can move a little, but uphills, its 5mph if she doesnt stall out. She's an automatic BTW. She's got some holes in the exhaust by the headers i need to weld shut but thats about the gist of the problem. I was thinking injecters, but i threw a ton of cleaner in and let her idle through a half tank of gas (all that was in it when i dumped in the cleaner) Then I thought it could be the gas itself, so i put half a tank of 92 octane in her. same deal. So now i'm thinking throttle positioning senor, but I'm not sure. I'm alright with mechanics but once we get into sensor's i'm still a newbie. I wouldn't mind some input or some other things to check.
Thanks in advance
Old Oct 23, 2006 | 11:56 AM
Salem's Avatar
Salem
In addition:
If you ease the throttle body in park, she will rev up, even with throttle body wide open. But if you dump the pedal in park, she bogs.
confusing!
Old Oct 23, 2006 | 12:21 PM
quicklook2's Avatar
quicklook2
what do the plugs, dist. cap and rotor, air filter look like?
change fuel filter.
this truck has two fuel pumps, either one may be bad.
battery cables may be corroded.
you need to start at the basics
Old Oct 23, 2006 | 02:57 PM
Salem's Avatar
Salem
changed fuel filter, airfilter is soso plugs cap and rotor are new, fuelpumps new and good, batter cables are good, but like i said the battery is bad. she gets enough juice froma jump to start though.
I did most basics.
Old Oct 23, 2006 | 03:16 PM
quicklook2's Avatar
quicklook2
get a battery before you do anything else.
Old Oct 23, 2006 | 08:45 PM
ranger6202's Avatar
ranger6202
fuel regulator?
