pyro problem
Old Oct 22, 2006 | 02:57 PM
cojab's Avatar
cojab
pyro problem
Does anyone have pics in their gallery of where they have mounted their pyro thermocoupler. I drilled and tapped mine into the pipe right before the turbo. Is this a good area? I am not getting any kind of reading right now. Actually it is getting to just over 100 degrees no matter how hard I get after it. I searched on this and saw some problems with the older Autometer pyro gauges. I'm just checking to see if I did everything right before calling or returning the gauge. I also ran the same ignition power line for both this gauge and the trans temp. Seemed like this was causing some problems before also. Should I change this?
96 F-250 PSD CC
6637 Intake 3" downpipe 4" Tymar Exhaust minus the cat
Autometer Phantom gauges
Waiting for Wildman chip
Old Oct 22, 2006 | 03:28 PM
ForemanES's Avatar
ForemanES
Double check the wiring, they are electric gauges. The probe sounds fine.
I have the same phantom autometer gauges and have had no troubles for 3 years.
Old Oct 22, 2006 | 04:23 PM
DaBigTow's Avatar
DaBigTow
Pyro power must be on a separate wire pair from any other item, even though it may have the same source. I learned that one that hard way.
Old Oct 22, 2006 | 04:49 PM
cojab's Avatar
cojab
If I change the power supply do i also need to change the ground or can that be on a common wire?
Old Oct 22, 2006 | 05:18 PM
DaBigTow's Avatar
DaBigTow
BOTH wires separate...
Old Oct 22, 2006 | 05:57 PM
cojab's Avatar
cojab
Thanks for the replies. I will change out both the ground and power tommorrow and let you know how it turns out.
Old Oct 22, 2006 | 06:00 PM
cojab's Avatar
cojab
Sorry to be a PITA but one more thought. Can both gauge power supplies be run to the same fuse on the fuse block or should that be seperate also?
Old Oct 22, 2006 | 08:29 PM
DaBigTow's Avatar
DaBigTow
It's ok to use a common source & ground; I did.
Old Oct 23, 2006 | 10:00 PM
cojab's Avatar
cojab
OK,,,, I ran new wire for both the power and ground on a seperate set of wires. Still have the same problem. Temp reads a solid 125 no matter how hard I get after it. I checked the power supply wire with a test light at the gauge and it has power. I also checked the red and yellow wires coming from the probe. Neither of these showed any power. Is this correct? The only other thing I can think of is the gauge came with a long set of wires for the power supply that was attached to the gauge. I had run my wires for power and ground to the gauge already and did not want a bunch of wire bundled up in the gauge pod so I cut these wires down. Should that make a difference? Should I reconnect these wires and run them directly to the power supply and ground? Is there something I should check with an ohmmeter to see if the gauge is faulty?
Old Oct 23, 2006 | 11:54 PM
DaBigTow's Avatar
DaBigTow
You should have very little voltage between the probe wires, something on the order of a few millivolts. If the wires you ran for gauge power are smaller than those provided by the factory, that could be trouble. Shortening the wire is OK. Can't think of anything an ohmeter can tell you, except for continuity thru the probe.
Old Oct 24, 2006 | 12:18 PM
cojab's Avatar
cojab
I guess one more thought before I drive over to the performance shop. I used teflon thread sealer (the putty type, not tape) on the threads for the thermocoupler into the up pipe. Does this connection need to be grounded? Is the thread sealant preventing a ground?
Old Oct 24, 2006 | 12:25 PM
DaBigTow's Avatar
DaBigTow
Thermocouples don't ground out through the tip; you should read infinity (open-circuit) from the tip to either wire of the sender. However, teflon sealer will burn out in nothing flat. The threads should be clean.
Old Oct 24, 2006 | 12:42 PM
Texmo's Avatar
Texmo
When you've exhausted all of your possibilities call the gauge manufacutrer. A buddy of mine had to send his back because it was malfunctioning in much the same way...I'm pretty sure is was an Autometer Pyro.
Old Oct 24, 2006 | 07:29 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Disconnect the thermocouple leads from the gauge and apply power to the gauge. If the gauge is reading ambient temperature the gauge is good and the probe is bad. If the gauge is not reading ambient then it is bad.
You didn't cut or otherwise alter the thermocouple leads did you? Additional reference junctions will change the readings.
Old Oct 24, 2006 | 09:31 PM
cojab's Avatar
cojab
No I didn't change the thermo leads at all. I will pull it out again and put power to those leads though and see what happens. I have double checked everything I can think of. Boost and tranny gauges seem to be working well. I'm making about 20 lbs boost when I really get after it around 2800 rpm. I had a 97 with a Banks system on it that I dont remember ever getting over 15 lbs. The 6637 intake and Tymar exhaust work well.
