Stalling problem - 76 F-250
Old Oct 22, 2006 | 01:35 PM
Junkyard Dog's Avatar
Junkyard Dog
Hi guys,<O</O
The 390 in this 4x4 runs very smooth 99% of the time. Currently I only use this truck to haul stuff to the dump, at least till I do some upgrades to make it a bit more presentable and reliable. Anyway, the last two trips to the dump the truck it ran great for about 7 or 8 miles and once I came to a stop and let it idle for a couple minutes it died. It starts again after a couple minutes and then coughs and spits for a second or two intermittently for the next couple minutes before running smooth again. <O</O<O
I suspect a clogged fuel filter or dirt in the carb but someone mentioned that it might be the Duraspark ignition module. I'm not all that familiar with Fords so I'm looking for some help here before I tear into this thing. <O</O<O
So is it just dirt in the fuel or is this symptom of a Duraspark problem?
<O</O
Thanks in advance for your help<O</O
Old Oct 22, 2006 | 07:11 PM
Thomasm67's Avatar
Thomasm67
Eliminate fuel filter and carb and then if the problem still happens then look into the ignition module and it's not exspensice to get another ignition for it.
Old Oct 22, 2006 | 08:12 PM
390Highboy's Avatar
390Highboy
I had a 351 powered f150 a few years ago that was experiencing a similar problem. I replaced the Duraspark module and everything was fine. Mine ran absolutely perfect before and after the little problem. It would just die without warning and start up later like nothing was wrong.
Old Oct 22, 2006 | 10:40 PM
timothy47129's Avatar
timothy47129
When you replace the filter also take off the top of the carb over the fuel bowl and look for crud in there.Some how over the years crap manages to get past the filter and accumulate.
Tim
Old Oct 22, 2006 | 11:18 PM
joes52f6's Avatar
joes52f6
Probably wouldn't hurt to change the filter anyway, but I would suspect it to be the module.
Old Oct 23, 2006 | 09:42 AM
1975Ford's Avatar
1975Ford
Listed are pre checks.
I agree too, change the fuel filters, and check for any cracked or worn fuel lines.
Sometimes when a truck sits for extended periods, the gas can become old and create engine running problems.
Also check all vacuum lines, check if they are cracked or the rubber hard. Replace if as needed. Check the vacuum line to brake power booster.
Old Oct 23, 2006 | 11:33 AM
brentleedragon's Avatar
brentleedragon
I had the same problem, except mine died while driving, so I replaced the fuel filter, cleaned the carb, and I had the lines replaced awhile ago when I first started working on the truck, also a big cause of this, is stuff built up in the gas tank(s) from sitting. My backtank I had to buy additive to break it all up and get rid of it, you might want to get some additive for the tanks if it is a dual or not and just fill it up completely, dump this in it, and you'll be good.
Old Oct 23, 2006 | 12:46 PM
Ford_Till_Death's Avatar
Ford_Till_Death
I had the the same problem as brentleedragon and did everything he did but it would still die while i was driving, blowing 2 mufflers. I changed the module and the mufflers and it hasn't done it since.
Old Oct 23, 2006 | 06:14 PM
Junkyard Dog
Thanks guys. I appreciate the insights. I'm going to change the fuel filter, install an aftermarket air cleaner assembly, replace the module and rebuild the wiring from the module to the distributor as well as replace the coil. The engine is a re-man unit from one of the local auto parts stores and is only about 3 years old but I'm quite sure all the accessories, wiring etc are vintage 1976 so it's probably about time to do this anyway.
<O
One more question. The guy at Auto Zone says I have to pull the distributor and disassemble it to replace the pickup. Is this true or was the Auto Toad blowing smoke? <O
Old Oct 23, 2006 | 06:57 PM
Mil1ion's Avatar
Mil1ion
Yes....remove it.
Old Oct 23, 2006 | 11:27 PM
1975Ford's Avatar
1975Ford
Can also buy a complete remanufactured distributer, it will come with new bushings, gear, and pickup coil, and vacuum advance.
