Lights not working?
Old Oct 22, 2006 | 12:53 AM
russell072009's Avatar
russell072009
Lights not working?
I recently had the pleasure of changing the battery cables on my 96 250HD. I'm pretty sure the cab lights worked before i changed the cables. Now the drivers side door jamb switch dosen't work so i have no warning tone for the headlights or interior cab lights. The switch is fine. I swapped with the switch from passenger side and they both work for the passenger door but not the driver. It's the oddest thing i've ever seen. The swith has 3 wires and both have 12V and the ground is good. What gives? I'm about ready to light this thing on fire and walk away i really am.
Old Oct 22, 2006 | 09:57 PM
russell072009
well just an update i pulled an alldata on the truck and apparently i have a wiring issue between the fuse and the switch. i actually tested it the right way and i have no power but the passenger side works fine....... that torch is sounding better and better.
