i need help
Old Oct 21, 2006 | 09:32 PM
ilovebeerdude's Avatar
ilovebeerdude
Angry i need help
i have a 95 ford f150 5.0 v8. i got it not to long ago and it has needed some work. i replaced the valve cover gaskets, and the upper intake gasket, cap and rotor, well now i put everything back together and the truck wont run right. i checked everything and it is all back the way it was. im not sure what to do. im trying to learn more on engine repair but now im in a bind. help me.
Old Oct 21, 2006 | 09:43 PM
quicklook2's Avatar
quicklook2
are plug wires on correctly?
Old Oct 21, 2006 | 09:51 PM
subford's Avatar
subford
Make sure you did not leave a vacuum hose off and do not forget that a 95 5.0 has the same firing order as a 351. It is not the same as the older 5.0 engines.
http://i54.photobucket.com/albums/g9.../CrossFire.jpg
Old Oct 21, 2006 | 10:05 PM
quicklook2's Avatar
quicklook2
i was looking for a link to your earlier post on crossfire.
thanks, subford.
Old Oct 22, 2006 | 07:45 AM
ilovebeerdude
ill try that today but i checked them three times yesterday. thanks guys
Old Oct 22, 2006 | 10:17 AM
quicklook2's Avatar
quicklook2
intake gasket may be leaking.
ign. wires may be bad.
double check the firing order and make sure it is for the year your truck is as they are different some years.
for 1995 plug firing order:
http://autorepair.about.com/library/...bl-fo-6596.htm
Old Oct 22, 2006 | 10:49 AM
subford's Avatar
subford
http://autorepair.about.com/library/firing_orders/bl-fo-6596.htm
This link has the wrong firing order.
Old Oct 22, 2006 | 10:57 AM
quicklook2's Avatar
quicklook2
shows that all info on web is suspect.
subford, maybe he was using this order and that is his problem.
Old Oct 22, 2006 | 11:08 AM
subford's Avatar
subford
I was thinking that may be the case and that is why I posted what I did above.
Old Oct 22, 2006 | 01:59 PM
ilovebeerdude
well it is running now but for some reason i thought of trying the older 302 firing order and guess what the truck is running just fine now. i dont understand why it is the old firing order on a 95. anyway im planning on selling this truck to get a new truck so if anyone is interested let me know.
Old Oct 22, 2006 | 02:47 PM
quicklook2's Avatar
quicklook2
might have had an engine change before you owned it.
glad it is running good now.
Old Oct 22, 2006 | 04:16 PM
lostin90s's Avatar
lostin90s
I had an 94 302 bought new it had old firing order. My newest toy is a 94 w/Maf 302 it had the new 351 order when bought it. Think it just depends what was FORD had left on shelf and how early that 95 was made in the 94 year.
_______________________________
94 F150 XLT 4x4 SC LB Maf 302 E40d
