Rpm's?????????
Old Oct 21, 2006 | 08:38 PM
RangerTuff05's Avatar
RangerTuff05
Rpm's?????????
What rpm should i be shifting my 360 FE at. I just put a tach in the truck and i was shifting it around 2400 but i didn't know how much higher i could push it.
Old Oct 21, 2006 | 09:59 PM
rusty70f100's Avatar
rusty70f100
Without blowing it up, you could probably go up to 5000rpm. I'd keep it below 4500rpm though, as anything more is wasting your time. If it's got the stock 2 barrel and stock exhaust manifolds on it though, anything over 3500rpm is probably wasting your time.
Old Oct 22, 2006 | 01:55 AM
390fe's Avatar
390fe
My C6 shifts at 4,300 rpm, wide open throttle.
Old Oct 22, 2006 | 02:02 AM
Bear 45/70's Avatar
Bear 45/70
A 360 isn't a 390.
Old Oct 22, 2006 | 11:52 AM
LedheadELH's Avatar
LedheadELH
well a 360 shouold rev higher, it's got the shorter stroke. it's just isn't built from the factory like the 390 is! JMO
Old Oct 22, 2006 | 03:38 PM
Bear 45/70's Avatar
Bear 45/70
Sure it has a shorter stroke, but it has a lower compression ratio too. The factory rates both the 360 and the 390 at 4400 rpm, but the real world is not what the factory gets with a perfect test motor.
Old Oct 22, 2006 | 06:40 PM
390fe's Avatar
390fe
Originally Posted by Bear 45/70
A 360 isn't a 390.
You got that right! But presumably we're comparing stock motors, and any differences would be so minor the differences would be negligible.
Old Oct 22, 2006 | 07:02 PM
390fe's Avatar
390fe
Perhaps I should clarify my original post. You can shift whenever you please. 2,400 rpm is ok, 1,500 is ok, whatever you want. I don't know why you'd need to shift at a higher rpm.
When my truck had it's original 360 and a four speed, I shifted it at a higher rpm when it had a load on it, than when it didn't. I normaly shifted at around 1,500 rpm.
Old Oct 22, 2006 | 09:45 PM
Bear 45/70's Avatar
Bear 45/70
I can agree with that.
Old Oct 23, 2006 | 09:02 PM
RangerTuff05
it just seems doggy and i wanted to know because i do a lot of trailer pulling
Old Oct 23, 2006 | 10:13 PM
Bear 45/70's Avatar
Bear 45/70
The 360 was never what anyone would call a "Power House". They won't rev very high and were only rated at 215 hp @ 4400 and torque is 327 ft/lbs @ 2400. That 215 was without the truck's exhaust. tranny or any accessories. It's never a bad idea to shift at or just past peak torque.
Old Oct 23, 2006 | 10:27 PM
LedheadELH's Avatar
LedheadELH
yea, but I bet if they got some more compression ratio they would run much better. basically identical to a 390, just not a stroker I guess you'd say, and w/ less compression......I dunno, they run forever though, even w/ no oil...lol.....Damn near bullit proof in stock form.
Old Oct 23, 2006 | 11:26 PM
Bear 45/70's Avatar
Bear 45/70
The truck 390 wasn't a power house either. Try 255 hp @ 4400 and 376 ft/lbs @ 2600 for the truck 390. Now the car motors, at least the 4 barrel one, we a totally different matter. Then again the was the 10.5 to 1 copressioned 2 barrel motor.
Old Oct 24, 2006 | 04:06 PM
LedheadELH's Avatar
LedheadELH
yea I know all about the differences...I ran car 390 pistons in the truck 390 in my Bronco.....made a world of difference!...lol
