87' Dual tank problem
Old Oct 21, 2006 | 01:55 AM
imchrislara's Avatar
imchrislara
OK When i switch to the rear tank, after a minute or so it will just stall out and i know for a fact i has over half a tank>??? its plagueing me becuase i know there is gas in that tank it jsut wont work. front tank works fine tho?
any help on trying to figure this out?
Old Oct 21, 2006 | 02:02 AM
grizz3000's Avatar
grizz3000
The front tank has its own internal electrical pump, I'm pretty sure (my 89 F250 does). The rear tank runs off an external pump. I was running of the rear tank for awhile until I fixed the main internal tank pump. In short: I'm pretty sure they have different pumps. Have you checked your fuel filter (an easy fix, and wouldn't hurt to put a new one on if you don't know how old it is)?
I'm a newbie so you might want to wait for an ol' timer to reply.
Old Oct 21, 2006 | 04:45 AM
metmag52's Avatar
metmag52
Both tanks have an internal pump on my 87 and 88---you need to check all the electrical connections too--a big problem up here in salt country(New Hampshire)
Gary
Old Oct 21, 2006 | 04:46 AM
metmag52's Avatar
metmag52
Hey--its also possable that the switch thingie under the cab is messed up--I have had that happen also.
Gary
Old Oct 21, 2006 | 08:00 AM
johnc486's Avatar
johnc486
I had the same problem on my 87, I disconnected the hose from the rear tank at the rail pump and switched the key on to see if fuel would pump from the rear tank, no fuel, new pump installed, all is well again.
