Sponsored by: Real Truck
Yet another Coil Pack
Old Oct 20, 2006 | 05:26 PM
mein2xshp's Avatar
mein2xshp
Has anyone else run into having to change multiple coil packs?
I just had to change another one, this will be 5 in the last 5 months. I have had the truck checked out by a buddy of mine who happens to be the Service Mgr at a local Ford dealer, and he says that there is nothing else wrong with the truck that would effect the coil packs.
This is getting crazy at $60 a pop
Old Oct 20, 2006 | 06:29 PM
billbain's Avatar
billbain
Summit has accel coils under $30.
Old Oct 20, 2006 | 06:53 PM
akford351's Avatar
akford351
From what I've read, if one goes out its best to change 'em all.
eBay has 'em cheap too...
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
These are for 10 but its a heck of a lot cheaper and you'll have spares. :b
Old Oct 20, 2006 | 09:04 PM
Cobra97Vert's Avatar
Cobra97Vert
man you are a life saver, that is an awesome deal. I buy everything of ebay and didnt look there 1st. I bought 1 from ford and will be picking up a set of 10 from ebay. Man I love this site
Old Oct 20, 2006 | 11:25 PM
Gnikhog's Avatar
Gnikhog
I've replaced 6 COPs on my 99 V-10 (so far) although none in the last 12 months. I only replace them when they fail. As you discovered, aftermarket parts are much more affordable. I am partial to NAPA's $60 replacement.
Old Oct 21, 2006 | 12:07 PM
mein2xshp's Avatar
mein2xshp
Well its not the repalcement cost as an issue but the fact that i just had to replace one yesterday and it was the second time that #8 went, and it was an after market one, thanks to akford351 i will be getting the set off e-bay now, i didn't even think of checking there first. I think that factory parts are going to be the best way to go on this issue, thanks guys
Old Oct 23, 2006 | 07:00 PM
qikgts's Avatar
qikgts
I bought from that seller. The 8 coils I bought are still working fine and have approx 10k miles on them...
Old Oct 25, 2006 | 06:50 PM
mein2xshp's Avatar
mein2xshp
Hey, thanks for the help guys, now i have another problem that i will be posting later.
Old Oct 26, 2006 | 05:18 PM
trimman's Avatar
trimman
Angry Cops
Word has it that if one is weak it will affect others? So, lots of times it's multible replacements. My 02 the first time was 3, then another one, then another one? What's crazy is that I know and the dealer I tell it's another one and they still charge for the diagnostics? My 99 had no such problem in 100K
Old Oct 26, 2006 | 05:36 PM
G-Dog's Avatar
G-Dog
if one go's just change them all and do the plugs i found weak plugs make them fail sooner
Old Oct 26, 2006 | 05:42 PM
Jim59's Avatar
Jim59
Makes you kinda long for the days when there was only one coil hanging off the distributor. :-)
Old Oct 26, 2006 | 07:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Actually, not.
It's best to change all the BOOTS at the same time.
I'd bet that the COPs are not really bad, the boot is shot, moisture/dirt got into it, and it's shorting out the spark.
Water is the worst thing on the OHC motors, because it gets down into the hole, and when the engine heats up, turns to vapor and shorts out the COP.
Of course, in terms of labor if you're having someone do the work, changing the COP is probably the easiest/cheapest thing to do.
Old Oct 26, 2006 | 07:30 PM
whatfish's Avatar
whatfish
I have done four so far #4 #6 #3 #5
i now have overheating issues
looks like a gasket of some sort has failed
Do all these Ford trucks fail constantly?
Old Oct 27, 2006 | 04:13 PM
G-Dog's Avatar
G-Dog
hay whats up the boots if the problem water can get in and short the plug but i had one were #1 was missing and it on had 40,000km and there was no water contamination the coil was the problem so i pulled the plug and it looked ok not crackded or worn it looked good put it together and had a miss in #1 but no as bad replased the plug all good it was a 250 with a 5.4 2003.
Old Oct 27, 2006 | 04:19 PM
whatfish's Avatar
whatfish
ok what was that?
