General Automotive Discussion
New here..please help!
Old Oct 20, 2006 | 01:08 PM
princessjazmyn's Avatar
princessjazmyn
Hey guys! I am new here and don't know where to post my question. So any help would be much appreciated.
I have a '95 Ford Windstar and am looking for a free owner's manual that I can download somewhere. My brake light is not coming on when I'm braking so I am looking for a fusing diagram so I can see exactly where the brake light fuse is.
Any suggestions??
Old Oct 20, 2006 | 01:57 PM
aerocolorado's Avatar
aerocolorado
Could be a burned out light bulb instead of a fuse. No diagram required to check/change that. More likely than a bad fuse or else both lights would be out. Might also post a query in the "Aerostar" forum. Not the same van but the people there are very helpful.
(On edit) Here's a site to download owners manuals. Fuse diagram will be listed in there.
www.fleet.ford.com/maintenance/owners%5Fmanuals/
(On edit) This is a BIG file. I downloaded it to see if the info was there. 1996 is the earliest model year listed, I used the 1996 Windstar. Fuse box diagram is on page 344, list of fuse functions is on page 345/346. Windstars apparently use a separate fuse for each tail light. Fuse #2 for LH tail/stop/blinker, Fuse #8 for RH tail light. Fuse box is under dash, numbers should be on cover corresponding to the inside fuse locations. Good luck!
Old Oct 20, 2006 | 02:08 PM
westtntrucker's Avatar
westtntrucker
i would also check the switch that is connected to the brake peddle to see if the harness has worked itself loose.
Old Oct 20, 2006 | 02:21 PM
Mil1ion's Avatar
Mil1ion
Welcome to the site Jaz,
You got the right forum here.
Here is another place for the wiring .
http://www.autozone.com/servlet/UiBr...3d801d3abb.jsp
