352 to whatever need help
Bore your block to 4.050". Yes, it'll handle it. Get your 390 crank, rods, and pistons like Bear said.
Then, for all intents and purposes, you'll have a 390.
Then to get your HP, port your heads, install a good cam.
There's a whole art of matching the cam to the compression ratio, so you'll have to do some research. Here's some links to get you started.
http://www.kb-silvolite.com/article.php
http://www.popularhotrodding.com/tec...on_ratio_tech/
http://www.kb-silvolite.com/calc.php?action=comp
http://www.cranecams.com/
http://www.compcams.com/
Also do some reading in the forum, come back and ask if you have questions.
