All of the headlight assemblys I saw on ebay were $80-100 per light. Thats a little rich for me.
I did read somewhere on here to use 1200 grit wet/dry sandpaper and polish it to a finer grit and finish with polishing compound. Use a good wax to slow the process down afterwards.
I had pretty good luck with a headlight repolish kit. I forget who made it but I found it at a local parts place. It was basically just two grits of sand paper and then a liquid polish.
If the insides of the lights are good I would give this a try. It's cheap and pretty effective.
