Air bag
Old Oct 19, 2006 | 06:49 PM
dyhrdford's Avatar
dyhrdford
Air bag
Hey guys! I have a 1996 F-150 eddie bauer ext cab. short box, 5.8L, auto trans, 4X4, with 200,000 miles. About a year ago or so, my air bag light flashes what I think is a code. It flashes twice, waits a second or two, then flashes three times. A long wait, then two, then three flashes. Code 23??? Anybody heard of this before? Any help would be great. Thanks.
Old Oct 19, 2006 | 07:29 PM
quicklook2's Avatar
quicklook2
your clockspring is bad.
you have to remove steering wheel to get to it.
disconnect the battery when working on the air bag, flashing or not.
Old Oct 20, 2006 | 06:37 PM
dyhrdford's Avatar
dyhrdford
WTF is a clock spring?? What does it do? How expensive is it? Can I get it at autozone?
Old Oct 20, 2006 | 09:16 PM
quicklook2's Avatar
quicklook2
from an earlier post:
Originally Posted by Popa Tim
search for clockspring. I would suggest use adv search and select only this 87-96 forum.
$100 dealer only part and about an hour to install. On some of our trucks the horn and cruise will no longer work either.
On my 94 those work fine so I just have to make sure I buckle up since the airbag will not deploy while there is a code.
Picked mine up at Autozone for a little cheaper. Easy install and has been working for the past year.
do a search on clockspring and you will find more info on how to fix.
