77 bed replacement
Old Oct 19, 2006 | 04:11 PM
hwykar's Avatar
hwykar
77 bed replacement
How much trouble is it to replace the bed on a 77 f 100.
Old Oct 19, 2006 | 06:46 PM
highboy1975's Avatar
highboy1975
8 bolts and a plug. probably the gas filler will need disconnected too. depending on how much trouble the carriage bolts give you, it could be done in as little as an hour if your not painting it.
Old Oct 21, 2006 | 05:42 PM
fordilicious's Avatar
fordilicious
look to see if the vent tube is on the correct side, or you'll have to do like i did and make it wrap around the filler tube
Old Oct 21, 2006 | 08:10 PM
trinogt's Avatar
trinogt
If Liquid Wrench or PB Blaster doesn't loosen up the carriage bolts enough to remove (impact wrench could be your friend here), then plan to take a small grinder and cut the bed bolt heads off, cutting in a square pattern like the square hole beneath them, and drive through.
Old Oct 21, 2006 | 08:19 PM
fordilicious
that works if you bed wasn't like mine. my truck spent it's life as a lwn spraying truck, the only part of the bed left was the side panels and the rails under the floor..so i torched them out
Old Oct 22, 2006 | 09:23 AM
78workhorse's Avatar
78workhorse
Don't forget the electrical stuff. Tail lights, side marker lights.
