Engine swap!!!
Old Oct 19, 2006 | 03:33 PM
kooltruck's Avatar
kooltruck
Smile Engine swap!!!
I have an 84 f-150 with a carb. straight 6 in it,can i swap in a 87 efi straight 6?if so what's all involved.
Old Oct 19, 2006 | 03:59 PM
desperado_18_2000's Avatar
desperado_18_2000
The engines physically can interchange without hassle. Everything between those two trucks engine wise is the same. where you are going to run into problems is trying to bring the EFI system over to the truck. Not that its impossible, its just going to be a headache trying to convert it.
Wiring, fuel tank, fuel lines, etc. If you have the time, and access to both trucks..go for it!
