electrical problem
Old Oct 19, 2006 | 01:56 PM
hotwings19's Avatar
hotwings19
electrical problem
I have a 91 ford f150 gas/propane 4x4 my battery kept on dying , so I replaced the battery and wire ends, everything has been fine but when I go for a longer drive than usual when ever i turn off the engine I cant start it again the battery seems drained. my next option may be the alternator. a little help would be appreciated thanks
Old Oct 19, 2006 | 02:35 PM
87 XLT's Avatar
87 XLT
Whats the voltage at the battery when it's running?
Should be around 14 volts.
Old Oct 19, 2006 | 02:39 PM
hotwings19's Avatar
hotwings19
its around 14-15 volts on the dash gauge
Old Oct 19, 2006 | 02:45 PM
mississauga's Avatar
mississauga
To be sure, use your multimeter and try checking at your battery posts to see if the results are the same.
