1992 Alignment Issues
I'm new here and have a question for you. I got new tires on my 1992 f-150 flareside about a year ago. along with the tires i got an alignment and balance. i've rotated them once since then but the two front tires are almost already bald? i just got back from monro, they put it on the lift and said the only thing they could think of is the steering box and the shocks? i know i know, it's monro but has anybody else had this problem? the steering has always felt "loose" from day one.
thanks for your help
mine's a 2wd. the *** end is higher than the front end and that's how i thought they were supposed to look. i think i'll just start chipping away a problem areas one by one. i don't have a lot of money but i have a friend that can get me good tires cheap. does anyone know where i good get a good set of shocks for cheap? i don't want to go all out with this thing. just want to make it comfortable and reliable you know?
The rake on the 2WD is very noticeable, but improves some when you do replace the OE shocks and get the alignment right. I never had severe edge wear issues, but did get a little cup wear on the fronts with the previous set of tires. Cup wear is usually due to weak shocks or worn suspension. I've got 143K on my '92 now, and still working on the 3rd set of tires. Came with General's on it, first replacement was Goodyear Wrangler HT's, and now I have Michelin XC LT4's on it. Got about 50K on the first two sets, and this set looks like it's gonna do 75K minimum. So, don't accept any bull about Ford Trucks with Twin I eating tires. Make sure the alignment cams aren't worn. I had 'em put on when I bought this set of tires, and believe me, I don't regret it. It'll fix the wobblies right up.
One more note about the alignment. When I had mine done, I had the shop set the toe in about 1/2 degree more than the Factory spec, and camber about 1/4 degree more positive. That way, running on the highway, it straightens the wheels up very nicely with the downforce. On a flat straight, I went two miles without touching the steering. You can feel the difference in town at 30 mph or so, but you'll see much better tire life if you drive a lotta highway miles.
i got new tires, an alignment, and balance from firestone about a year ago. do you think it'll be worth going down there and bitching them out? they obviously didn't do a good job.
- oil pan
- water pump
- shocks
- tires
- front breaks
- exhaust
- allignment
-rear shocks
-oil pan
-front breaks (mayber roters too)
-water pump
-radiator
this thing's a money pit but i love this truck too much to give up on it. the body is still in pretty good condition. i'll post a pic sometime soon if anyone's interested?
Is your Flareside 2WD? If so, and you have access to a floor jack, it'll take about 1 hour per wheel for the novice to change out the front brake pads, and that includes the time to jack up the truck. There are no bolts holding the calipers on. Just two rubber pins with steel sleeves that can be driven out with a drift punch. Knock the caliper off, compress the piston with a C-clamp, drop the new pads in, slide it back on, and drive the pins back in. My mouth flew open when I saw there were no bolts in the calipers.
Changing the front rotors isn't much more difficult. You can do most of the work before you jack up the truck. Since the rotor also houses the outer races for the wheel bearings, you can press in the races in a new rotor, pack the bearings, and install the new seal before you even jack up the truck. Then, jack it up, remove the wheel, remove the caliper (see above) pop off the grease cap, take the spindle nut off, and yank off the old rotor. Clean it up as needed, slide the new rotor back on, preload the bearings with the spindle nut and close it up. If you did the rotors and pads at the same time, it'll cost you about $50/rotor, and anywhere from $30 to $400 for the pads, depending what you want to spend on 'em. Before I spent money on new rotors, though, I'd get the old ones checked for thickness. If they haven't been turned too much, and aren't grooved too badly, you may be able to have them turned at your favorite parts house or Express Oil, Jiffy Lube, etc. Any place that offers brake service. They'll probably charge as much to turn the old ones as a new set will cost though. One thing to bear in mind, do NOT buy cheap rotors, ESPECIALLY composite rotors. If you don't have the jack to go to Ford for rotors, at least get BENDIX rotors.
