need to add a battery
Old Oct 18, 2006 | 11:03 PM
jhchavez's Avatar
jhchavez
i need to find out if i can add a battery to my 2000 excursion i have a v10 engine do not have a cold air intake
Old Oct 20, 2006 | 04:40 PM
Monsta's Avatar
Monsta
Sit. Stay.
Yes you can.
What do you need the second one for?
Old Oct 20, 2006 | 08:25 PM
jhchavez's Avatar
jhchavez
for my stereo for an amp
Old Oct 20, 2006 | 11:43 PM
RACERX7775's Avatar
RACERX7775
yeah, what kind of mods do we need in order to make it mount properly and securely.
Old Oct 21, 2006 | 06:01 PM
Jetfixr's Avatar
Jetfixr
This link may help
http://www.wranglernw.com/pc-6362-84...1999-2004.aspx
Jerry
Old Oct 21, 2006 | 07:55 PM
jscarb2's Avatar
jscarb2
i did it just like the diesel's just mounted a battery with some screw down mounts and ran pos. to pos and grounded neg to the frame. it works but you pull power off both not just one so it can drain them both if left on. a battery isolator would give you more options but this works for me. with all my tv's on and the stereo up on 10-12 my lights will go almost out! (before the duals)
Old Oct 21, 2006 | 11:24 PM
RACERX7775's Avatar
RACERX7775
thats cool but wont the air filter thingy get in the way? it also has a selector for dual on, dual off, and emergency? if you have the selector to dual on, and forget to set the switch to dual off, wont it kill both batts if you leave something on? it doesn't really seem like an isolator does it? i guess ill call them to see how it works. oh, $400 seems way steep. you could buy a ford battery tray for a diesel X, and some -2 battery cable for a whole lot less.
