7.3l Problem
Old Oct 18, 2006 | 07:28 PM
f2501999's Avatar
f2501999
7.3l Problem
Is There Any Test That Can Be Done To Check If Valve Cover Harness Is Bad.
Old Oct 18, 2006 | 07:32 PM
PSNut's Avatar
PSNut
I'm willing to bet it's just a visual inspection since it's not a particular sensor.
Nut
Old Oct 18, 2006 | 07:35 PM
f2501999's Avatar
f2501999
Just Woundering Before I Pull Valve Covers Off To Check
Old Oct 18, 2006 | 07:40 PM
Uzumati's Avatar
Uzumati
You can ohm them out to block ground instead of the common ground. Its not 100% accurate if your problem is intermitant. Kinda like if you get a closed circuit it points to a short in the harness but just because you dont doesnt mean its good
Old Oct 18, 2006 | 07:44 PM
f2501999's Avatar
f2501999
Im Trying The Process Of Elimination To Figure Out The Problem With My Truck
Old Oct 18, 2006 | 08:30 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
well, what would that entail?
Old Oct 19, 2006 | 01:38 PM
f2501999's Avatar
f2501999
I Replaced Fuel Filter And Cps
