power door lock question
Old Oct 18, 2006 | 07:05 PM
blue 2004 FX4's Avatar
blue 2004 FX4
Has anyone with a supercrew ever wanted there doors to unlock when the truck is turned off? I asked the dealer if they could get this done and they said it is not possible, frankly I find it annoying that the doors don't unlock when the truck is turned off. Just wondering if anyone else thinks the same way.
Old Oct 18, 2006 | 07:20 PM
BigDfromTN's Avatar
BigDfromTN
You can change it to NOT lock when you take off.
Would that help?
BTW I find it annoying I have to turn on the cruise every time I turn off the truck on a trip etc.
Old Oct 18, 2006 | 07:30 PM
blue 2004 FX4
Thats a thought but I think I will leave it to lock itself, I have kids in the back and prefer it to lock on take off. Thanks I may try that though.
Old Oct 19, 2006 | 04:34 PM
GordoPanocho's Avatar
GordoPanocho
This topic has been discussed a few times. The only potential option is an aftermarket alarm setup which would allow you to 'mess' with the wiring. I think I've read where at least one particular variety works, but it won't be cheap. You'll probably just have to get used to having to hit the unlock button ... just like the rest of us.
Old Oct 19, 2006 | 08:08 PM
blue 2004 FX4
Thanks G, I thought I had to do that but I thought I would ask. Still I would like a ford rep to listen to this thread, GM has this on all there vehicles.
Old Oct 19, 2006 | 09:31 PM
awu_gigabyte's Avatar
awu_gigabyte
My viper alarm added this feature, but i had them turn it off, since i only have a super cab, and the handles unlock the door when you pull on them.
Old Oct 21, 2006 | 08:16 PM
blue 2004 FX4
Thanks I may consider this. I used to have a supercab too, and it was no problem for me either, but the 4 door is a pain!! Thanks again
Old Oct 26, 2006 | 01:41 PM
brad3384's Avatar
brad3384
I also think it is a pain in the a-- but not alot we can do but just remember to hit the button.. HA HA
Old Oct 26, 2006 | 01:55 PM
whitecrystal1's Avatar
whitecrystal1
Yep, I also got a Viper alarm/starter and had them wire it to lock and unlock my doors. I did have to turn off the oem auto lock because they both would lock the doors and I didn't want to wear out the actuators.
Old Oct 27, 2006 | 02:22 AM
cool guy's Avatar
cool guy
you can also get an upgrade to your keyless entry to full alarm system, you will be able to use the original remote, plus if you got a keypad, works great too... simple fact that you can still unlock/disarm and lock/arm the system without your remote....hopefully this help, oh BTW it will resolve your problem about the door locks too....
Old Oct 27, 2006 | 07:26 AM
whitecrystal1
The oem alarm came with two new remotes when I looked at it and the oem remotes wouldn't work with it. I was going to get it at first but it an oem aftermarket system anyways and I've had good luck with DEI. So I bought a viper instead.
