7.3 diesel
Old Oct 18, 2006 | 04:28 PM
bigbubba87's Avatar
bigbubba87
Smile 7.3 diesel
I am new to the site and the other posts have helped me fix some problems on my two truck i have an 87 f250 with a 6.9 diesel with and automatic trany i was wondering if i could buy a 7.3 and bolt it right up to the trany or are the bellhousings not the same?
Old Oct 18, 2006 | 06:58 PM
ltfox's Avatar
ltfox
Yup...it should bolt right in. As long as its a IDI diesel
Old Oct 19, 2006 | 04:59 AM
Saigon's Avatar
Saigon
If the 7.3 is from a "E" series truck you will need to swap the motor mounts, swap the oil cooler, engine oil dipstick and tube and also the driver's side exhaust manifold.As Itfox said above,bell housings are effectively the same but don't forget to leave the converter on the tranny when reassembling, I didn't and it cost me a tranny pump!
Old Oct 19, 2006 | 06:48 AM
bigbubba87's Avatar
bigbubba87
Thanks, it has a 6.9 with an automatic trany now and im rebuilden the truck i was thinking about putting a 7.3 with a 5 spd in it how would the transfercase bolt up to the 5 spd or would i have to get a different one.
Old Oct 19, 2006 | 09:55 AM
Saigon's Avatar
Saigon
I don't know much about the five speed but If it has a C6 I would keep it, its a great auto tranny, I've pulled stumps with it and hasn't let go yet, I'm not sure I could have done it with a manual tanny without burning the clutch!All depends what you want to do with your truck.
Old Oct 20, 2006 | 10:14 AM
Hamberger's Avatar
Hamberger
Got a ZF5 in my 93 F250 and it bolts up to a BW1356 transfer case. Check your transfer case.Seb...
Old Oct 20, 2006 | 08:11 PM
bigbubba87's Avatar
bigbubba87
thanks for the replys ill see what i can figure out
Old Oct 20, 2006 | 08:54 PM
blackestate's Avatar
blackestate
Should bolt up, maks sure the 5 speed is 4X4
