coolant leak
Old Oct 18, 2006 | 12:37 PM
RobertJohn's Avatar
RobertJohn
Question coolant leak
My son has an "03 and is losoing coolant.
Tech said something about the degas or however it's spelled
was cracked and leaking..
Is this an issue with 6.0"s ??
What is the cost of a new one ??
My 7.3 is fine but his isn't.. Are they the same res's ??
Old Oct 18, 2006 | 12:48 PM
blackhat620's Avatar
blackhat620
RobertJohn,
Cracking of the degas bottle is not a known issue to the best of my knowledge. That being said the bottle is plastic so it could crack for several different reasons.
Do not know the cost of a new bottle, you can go to discount ford parts (FTE sponsor) website and find out the cost.
www.discountfordpartsaty2kford.com/
Hope this helps
Old Oct 18, 2006 | 12:56 PM
RobertJohn's Avatar
RobertJohn
Thanks, I'll check and see. Is it called by another name or just degas ??
Old Oct 18, 2006 | 01:31 PM
blackhat620
RobertJohn,
Try Reservoir. $46.04 plus shipping
http://www.trademotion.com/partlocat...04&catalogid=2
Hope this helps
Old Oct 18, 2006 | 06:24 PM
CanadaGuy's Avatar
CanadaGuy
The reseviors do crack. Not too often, but still do nonetheless. If it's blowing out around the cap, I'd say you have something else going on.
Old Oct 21, 2006 | 09:40 AM
jasfaa's Avatar
jasfaa
There was a TSB to not fill the Degas bottle to the max line but the min line. This stopped mine from leaking.
