clutch squeaking
Old Oct 18, 2006 | 11:44 AM
gbeach's Avatar
gbeach
clutch squeaking
Man,I don't think anything is going to quit breaking on this truck. 93 f250
7.3l 5spd. When I push the clutch in, I am getting a squeaking noise. My clutch master is brand new. It sounds like it is down by the slave, I am waiting on my wife so she can push the pedal while I listen. It started out as a popping noise, then went to a squeak. it only squeaks at a certain spot on the pedal movement. anybody had this.
Old Oct 18, 2006 | 12:13 PM
bc6.9's Avatar
bc6.9
The beauty of owning a diesel is usualy you can't hear any squeaks...but that doesn't solve your problem. The most common of squeaks associated with clutch I found is the spring on the cross member under your dash and cracked firewalls [ 93, I don't think had problems with firewalls] , but you hear it around your slave cylinder?? It must be a loud squeak...can you hear it with the truck running? With a hydrolic system, the only moving parts are the master & the slave no noise there, so with a "new master" is it possible your getting a full throw and now hearing pressure plate spings??
Old Oct 18, 2006 | 12:20 PM
gbeach's Avatar
gbeach
when you say crossmember, are you talking about the pedal, or under where the slave is. I can't hear it with truck running. I was just worried, because it started out as a pop when you release the pedal, then went to a squeak. you might be right maybe it is just the pressure plate. I don't know which spring you are talking about though, I don't recall one under the truck
Old Oct 18, 2006 | 12:28 PM
bc6.9's Avatar
bc6.9
The spring I'm referring to is under your dash attached to your clutch pedal and cross member. If thats where the squeak is...give it a good spray with any lubricant. lol
Old Oct 18, 2006 | 08:25 PM
Dave Sponaugle's Avatar
Dave Sponaugle
May need to get some lubrication on the clutch fork pivot point in the bell housing.
Should be able to do that from the outside, I know I can on my four speed.
Could also be the rod that comes out of the slave cylinder where it meets the clutch fork.
Old Oct 25, 2006 | 07:23 AM
gbeach's Avatar
gbeach
how do i do that from the outside.
Old Oct 25, 2006 | 07:32 AM
86fu50's Avatar
86fu50
Pull the rubber boot off the bell housing where the clutch fork goes in and give the pivot point a good spray.
Old Oct 25, 2006 | 08:35 AM
gbeach's Avatar
gbeach
my clutch is hydraulic, are you talking down by slave cylinder.
thanks for reply.
Old Oct 25, 2006 | 01:55 PM
86fu50's Avatar
86fu50
yes, the slave pushes the clutch fork
Old Oct 25, 2006 | 02:09 PM
gbeach's Avatar
gbeach
gotcha, now i understand. i'll try it. it is definitely coming from down there.
thanks
