fuel issues
Old Oct 17, 2006 | 08:36 PM
wesw0000's Avatar
wesw0000
fuel issues
i have an 86 f-150 302 efi its always running like im flooring it. when i sit at a red light it tries to pull itself out from under me. i can put it in neutral and it sounds like im gassing it. what would cause this?
Old Oct 17, 2006 | 09:47 PM
desperado_18_2000's Avatar
desperado_18_2000
Sounds to me like a massive vacuum leak if the truck is idling waaaaay up high. Also if yours is fuel injected it might be your Idle Air Control motor which is attached to the side of your throttlebody.
Old Oct 17, 2006 | 10:42 PM
petrofix's Avatar
petrofix
Get a few cans of non-flammable brake parts cleaner and start hosing down hoses and fittings, with truck parked and at idle. If an air leak sucks the stuff up engine idle will changes.
Old Oct 20, 2006 | 02:09 PM
wesw0000's Avatar
wesw0000
thanks. yeah it is fuel injected plus it only does it sometimes. other times it runs fine.
