egr valve removal
Old Oct 17, 2006 | 08:02 PM
atvraptorman's Avatar
atvraptorman
egr valve removal
Whats the best way to take out the egr valve? I seen someone on here have wires in the two holes, looped around, I guess for pulling it out. Can you just take the bolts out and grab it and pull it out? Whats the tq specs for the bolts?
Old Oct 17, 2006 | 08:18 PM
BowTieHatr's Avatar
BowTieHatr
there is a speacial tool for removal, not sure what it is because i have never used it. if you have lady foot prybars you can prop it under the lip and pry up. i use a pair of channel locks gripping the sides with the channels over the connector, then use a prybar to pop it out.
