Cant Take Door Panel Off Expy
Old Oct 17, 2006 | 06:36 PM
atoztech's Avatar
atoztech
My Left Front Mirror Broke And Ive Taken Plenty Off Door Panels Off Before But This One Is Really Breaking My Stones. Anyone Doe This Before And If So What Is The Trick. ITS A 1999
Old Oct 17, 2006 | 06:47 PM
bridge's Avatar
bridge
Sick 'n Tired
Make sure you remove the interior handle, the screw inside the light and the ones along the bottom. Pull up then out...
Old Oct 19, 2006 | 06:20 PM
ATLoffroad's Avatar
ATLoffroad
Getting off the door panel
On the front door first you need to pull off a small triangle shaped panel just on the other side of the door of the side mirror. It just snaps off. Once it is off you need to take out the screw that was underneath the triangle shaped panel. Next you need to take out a bolt that holds the handle that opens the door. Once you get that handle off just push the entire panel up. This will unhook it and you are all set.
The back door is even easier. Just take off the two screws at the very bottom and push up and its off.
Old Oct 19, 2006 | 08:18 PM
Swordfishfur's Avatar
Swordfishfur
There's a screw behind the lens in the light at the bottom of the door too.
Old Oct 20, 2006 | 01:44 PM
madsonp's Avatar
madsonp
There is also a screw hidden up under where you pull the door handle off, that's the one I had a hard time finding
Old Oct 20, 2006 | 01:50 PM
belldawg's Avatar
belldawg
Make sure to do what "Bridge" said. Up and then out. I took all the screws out of mine and just yanked and well most all my brackets are broke now. Make sure to go up with it first.
