Sponsored by: Real Truck
Adjusting headlights
Old Oct 17, 2006 | 06:19 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
As of this afternoon, my truck will be sitting roughly 10" higher in the front, than stock. i have Silverstars and the harness, and i know i already blind people, however being even higher, i will know that one cop will get me thinking that my high beams were on.
how do i adjust only the headlights down? is it as easy as turning a screw or what? before the lift i shined the headlights on the garage door and made a mark, and after the lift, it was the same spot that they shined on, however i know they will need adjusting.i would like to do them this afternoon. thanks alot guys
Old Oct 17, 2006 | 12:39 PM
Green_Dually's Avatar
Green_Dually
Yes there is a screw,behind the headlight.There are 2 of them.One to adjust the height and one to adjust side to side.
I believe that there torx bit.
I think the inner most screw is the one you want to adjust.
Hope this helps.
