Aerostar Ford Aerostar
Water pump issue.....
Old Oct 17, 2006 | 01:51 AM
Pablo-UA's Avatar
Pablo-UA
Just changed coolant, and water pump started leaking....
Is it possible to fix it, I never saw a kit for aeros pump...., who knows what is the bearing and seal sizes, mai be I can purchese a lit of european make....
Old Oct 17, 2006 | 07:46 PM
xlt4wd90's Avatar
xlt4wd90
Pablo,
I am impressed that you will try to fix the water pump. I replaced mine when it blew out its bearing/seal. I should have kept the old core to take apart, but I already have too much junk in the garage. Good luck finding replacement bearing, and let us know measurements when you can get them. Maybe some others on this forum can replace just the failed component, instead of the whole pump.
Old Oct 18, 2006 | 12:56 AM
Bear River's Avatar
Bear River
Former ******
Just replace the water pump. They are really cheaper than rebuild kits in the long run. Of coarse that is here in the US, I'm not sure what kind of price you would see, maybe they are way expensive. It just seems to me that by the time the bearing fails, that there is a strong possibility that corrosion has set in on other parts of the pump, and it would be better to let someone who rebuilds these for a living handle it and let you get the the important work of getting your ride back on the road.
I have no idea as to where you would get a bearing, but my guess is that if you knew that, you wouldn't be asking here. Maybe one of the older members has done this before. I personally wouldn't bother, not when I can get a new part and have a warranty to go with it.
Old Oct 18, 2006 | 03:38 AM
Pablo-UA's Avatar
Pablo-UA
$80 in Ukraine! is it good price? My pump was made in 1989....
Old Oct 18, 2006 | 05:37 AM
96_4wdr's Avatar
96_4wdr
hi pablo,
almost no DIYer home auto water pump rebuilding here in states any more...shafts, seals and bearing are not even commonly available and not listed on Motorcraft site
rebuilt here $25
new Motorcraft $75
Old Oct 18, 2006 | 06:35 AM
Pablo-UA's Avatar
Pablo-UA
I can not understand, where is the leakage? All the engine is dearty... But I can see something green under the engine every morning
Old Oct 18, 2006 | 08:43 AM
AeroBay's Avatar
AeroBay
Hi Pablo,
There is a hole directly underneath of the pulley, You will miss it if not looking for it. Mine started leaking from there and I couldn't figure out where the coolant was comming from. It leaks from there when the pump seal is shot. It was a bear to take off (Just like anything on the Aero )
Good luck
Old Oct 18, 2006 | 08:48 AM
Pablo-UA's Avatar
Pablo-UA
interesting quation... Why she started leaking after coolant change?
Old Oct 18, 2006 | 09:27 AM
Bear River's Avatar
Bear River
Former ******
Probably because the seal was plugged with junk or something, and it got flushed away. The little hole on the underside of the shaft is called a weep hole, and without it, the wate leakages would immediately get into the bearing and the pump would seize withot warning. This way, the leaking antifreeze will let you know there is a problem before it gets that bad.
Old Oct 18, 2006 | 01:38 PM
96_4wdr's Avatar
96_4wdr
or radiator cap was not sealing tightly forcing cooling system pressure to rise to specs of 16psi...
took cap off to change coolant thus cleaning cap seal....pressure went up to specs
Old Oct 18, 2006 | 03:43 PM
xlt4wd90's Avatar
xlt4wd90
That weep hole is usually blocked by the harmonic damper from below, so most of the time you will not see it even if you were crawling around underneath looking for it.
Old Nov 1, 2006 | 07:06 AM
BrokenSockets's Avatar
BrokenSockets
Absolutely replace. The question on this part is - how much is your time and agrivation worth vs. a relatively easy replacement? You should get the core charge back anyway.
Just remember to loosten the fan shaft before you take the belts off. It can be a pig to take apart afterwords.
Old Nov 1, 2006 | 08:59 AM
Pablo-UA's Avatar
Pablo-UA
It is strange.... But my pemp stopped leaking!!!!! New pump costs here about 60-70 Euro... Not too expencive... but my is OK now!
Old Nov 1, 2006 | 10:15 AM
copper_90680's Avatar
copper_90680
Ran out of coolant?
Old Nov 1, 2006 | 12:11 PM
96_4wdr's Avatar
96_4wdr
probably piece of block rust lodged in seal....thrown out and seal started working again
could have been one of these Mercedes SUV's, friend had to have water pump replaced....just off warranty....almost $1000
