i need advice!
Old Oct 16, 2006 | 04:23 PM
87ford's Avatar
87ford
i need advice!
i have a 87' f 250 with a manul 4spd with the granny gear..i know thats the other fourm but i dont want fuel injection..i have an edlebrock rpm performer intake..holley600 carb and a crane cam ready for my small block 302..but since it wus set up for fuel injection.. i need to change the fuel pump and ignition..please if anyone has any advice on what parts i need or any advice at all id highly appriciate it! thanks ..
Old Oct 25, 2006 | 06:29 PM
bollyfoxin's Avatar
bollyfoxin
in case you haven't gotten any advice yet[i don't play on the computer much]-i did the 5.0 swap on my 87 t-bird turbo coupe- as for fuel pump i wired in at the safety relay which on the bird is pink and gray wires.a lot simplier than changing tank sending unit,timing cover, lines etc.for ignition you could ****** a duraspark11 system out of an older truck-mid 70's to early 80's or-- even simplier i took a points distributer and put a module to replace the points[pertronics i think the brand]. a lot of people disagree with me, but personally i prefer to tell the engine what to do-not a computer running the show-just too old fashioned i guess. good luck!
Old Oct 25, 2006 | 07:19 PM
Sycostang67's Avatar
Sycostang67
Get a fuel pump for an 85-86 F-250 with a 460. It's a low pressure pump since the 460's were still running carbs. I think the 460 was still carbed in 87 too, so that might work as well.
Old Oct 26, 2006 | 03:43 AM
Redneck1465's Avatar
Redneck1465
You can also get a fuel pump for an 85 F150 with a 351. That will work as well.
Old Oct 26, 2006 | 05:12 PM
ford4ever4wheeler's Avatar
ford4ever4wheeler
1987 was the last year ford had carborators on 460's
