need help!!!!!!!!!!
Old Oct 16, 2006 | 01:17 PM
dnmccy1's Avatar
dnmccy1
Smile need help!!!!!!!!!!
I put a new 351 windsor high output engine in my truck with a edelbrock performer intake on it and the ignition timing is set at 10 degrees btc but the engine spark knocks , so my question is what should i set the timing at to take care of this problem?
Old Oct 16, 2006 | 01:29 PM
DAJF150's Avatar
DAJF150
What year truck? and what year H.O. 351 did you put in it. When you timed it , did ya dis-connect the SPOUT connector? Maybe you are too far btc, like 14 plus btc and is pinging/knocking? just a guess since we do not know the detail information.
Old Oct 16, 2006 | 01:36 PM
dnmccy1's Avatar
dnmccy1
the truck is a 1987 F-150 i put a 1987 351 ho in it and yes i disconnected the spout connecter it had the egr on it from factory but i took it off and put the manifold on it
Old Oct 16, 2006 | 01:45 PM
DAJF150's Avatar
DAJF150
Did you replace with a different displacement motor size, or did the original motor in your 1987 truck also have a 5.8L (351) as well? Reason I am asking is because the firing orders are different between 5.0L and 5.8L engines, and others.
Old Oct 16, 2006 | 01:48 PM
dnmccy1's Avatar
dnmccy1
no it had the factory 351 h. o. in it from the factory
Old Oct 24, 2006 | 12:48 AM
nighthawk285's Avatar
nighthawk285
You said you put in a "new" engine. Are you sure it didnt knock from wherever you got it before?
Old Oct 24, 2006 | 07:52 AM
dnmccy1's Avatar
dnmccy1
no it didn't knock before unless the machine shop did something wrong but i wonder if i change the dist. curve if that would make a difference
