Sponsored by: Kumho
copper question
Old Oct 16, 2006 | 11:44 AM
tewferford's Avatar
tewferford
Question copper question
I was talking to someone on another forum. He was talking about copper brake lines. Would anyone here consider using copper for there brake lines. And why or why not.
Old Oct 16, 2006 | 02:35 PM
SoArkSI's Avatar
SoArkSI
i have been told that brake fluid would deteriorate copper.
Old Oct 16, 2006 | 02:50 PM
tewferford's Avatar
tewferford
Thats what I'm think too. Thats why I posted it here. Lets give the pros a crack at it.
Old Oct 16, 2006 | 03:01 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
To the best of my knowledge it's a real NO NO. I doubt the copper would hold the pressure demanded in a full scale panic stop. And the corrosion factor in salt environments has to be considered. Absolute best would be stainless. Most vehicles have plain steel lines, and I have seen these develop corrosion to the point that pinhole leaks occur. JMHO, as usual.
Old Oct 17, 2006 | 07:25 PM
rebocardo's Avatar
rebocardo
Reasons not to use copper.
Copper will stress harden from vehicle vibration and crack.
Copper tubing usually has a seam.
Old Oct 17, 2006 | 07:40 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
Actually the copper used in refrigeration service would probably resist stress hardening pretty well. and is usually seamless. That said, max pressures in refrigeration seldom exceed 300-350 PSI, way below that which would be encountered in a hydraulic brake system. The Home Depot/Lowes stuff may very well be of seamed construction, and will very likely be subject to metal fatigue. You might loose some groceries if a refrigeration line failed, you might loose your life if it failed in a brake system.
Old Oct 17, 2006 | 10:06 PM
plowpusher's Avatar
plowpusher
copper will not hold the double flair (it will split) and will not hold brake pressure! never use copper for brakes!
Old Oct 18, 2006 | 04:58 AM
tewferford's Avatar
tewferford
So far that is exactly what i have been telling him. He claims someone actually makes copper brake lines. Anyone hear of this?
Old Oct 18, 2006 | 05:57 AM
alchymist's Avatar
alchymist
"Mifflin Clay"
Yes, BUT, they are a copper PLATED steel line. Supposed to resist corrosion, but more of a marketing gimmick. I think some steel lines (the grey colored ones) are also plated to resist corrosion.
