I am looking for a computer program that will read all of the engine codes and monitor the sensors, does anyone know of a program, I would like to run it on a laptop or Carputer I ambuilding to be able to monitor the engine while driving.
Great thanks. Can you monitor engine temp, oil temp/pressure, and trans temps with this set up. I have seen some programs for the Big Cummins engines in our buses that put up a digital display to monitor those while driving.
Depends on the year of you truck. My 01 the Coolant temp sensor is a "state" (normal/To hot) rather that a temp reading. the High pressure oil pressure can be read and the oil temp and trans fluid temp.
